Supercharger Bearing?
That is not right.
That actually sounds like the couplers have gotten loose. They're small polymer dowels around the pins that go between the snout and the rotor base. You might be able to give it a test by removing the SC belt and wriggling the pulley back and forth to see if you feel and or hear any play.
You can probably fix those up yourself. I'd ask Jesse at SDG Motorsports about it and see what he'd recommend.
