- Member ID
- #1155
- Messages
- 11,710
- Reactions
- 19,827
- Likes
- 352
- City
- West Texas
- State
- TX
- Country
- United States
- Vehicle
- 2017 Charger HC (once upon a time)
So, first off, let me say, this comparison is not as scientific as I originally intended. There was a delay of some 3 hours or so between the 555R end-of-life bench marking and the installation and testing of the M/Ts; also, under the current conditions I was not able to record nearly as much of the data as intended. I will provide as much information as I can and you can draw your own conclusions. I'll also post my own conclusions at the end. Both tires on 11x20s; 305s. Altitude 2580.
BASELINE 555R - these were nearly bald 555Rs, second set. Inflated (at running temp) to around 32 psi. Outside temp 70, ~20 mph cross wind, 23% humidity, barometer 27.10. TXDOT high-temp resistance composition asphalt (mild dust burden). Approximately 14 0-60 runs. Custom setting Track for everything except Suspension (Street, for weight transfer), and Traction (Sport, for full off - recall that in Track mode Trac still functions but with a different set of algorithms and I've never been able to find clear parameters even from Dodge SRT).
Result: One 3.8, 2 or 3 = 3.9, bunch of 4.0, one 4.1. Much spin on launch (several aborts when the rear broke free completely). Careful throttle management is essential to a good launch; even critical.
BASELINE MT - several hours later. Newly installed; probably 20 - 30 miles on them before the runs. Running temp pressure 38 psi. Outside temp 58, 13 mph wind off the port quarter, 33% humidity, barometer 27.17. Same surface. Six runs. Same settings. Visually appears a little wider than the 555R but this may be observational bias since they are new, clean, and still have the "spikes" on them.
Result: One 3.7, two 3.8, two 3.9, one 4.0 (maybe zero 4.0). No aborts. Slower runs initially because still launching in 555R mode, trying to avoid as much wheel spin as possible. All runs back to back; best runs at end. Anticipate with just a few more runs would have easily hit a 3.6, possibly consistently. 3.6 is the best I've ever run in that location on 555Rs and it was actually done in 46 degree weather with a set of 275s on the OEM rear wheels. So, just slapping these MTs on and running a 3.7 is significant. More forgiving on launch technique; easier to launch well.
Overall impression: the MT is far and away the stickier tire. It has more "float" and "bounce" (for just that reason) than the 555R but I'd never run the BBORR with these as rears anyway. For street driving, the way I drive, I expect these to be the best tire I've ever had on the car. Still need more testing to determine limits of the launch but on initial usage it is significantly better than the 555R. I am going to be mindful of that float though, given the experiences I've had before at 100 plus going into left hand sweeper with rough surface at WOT, until I have a better guage on the handling. When I got after it on the street with some spirited pulls on the way to the "track" I could tell a difference too. Much better grip. My advice: based on limited testing so far I would say this is a good candidate for replacing your 555Rs.
Hope this was useful.
- Show All
