QuickJack Portable Car Lift for only $899
You guys gotta quit making me wanna spend money.
Of course. I live in podunk NOWHERE...with exactly ZERO Costco stores ANYWHERE CLOSE.
Fml.
Fml.
Road Trip!
Wonder how these would work on my sloped driveway ? :(:rolleyes:
Great price tho.
Hemiride
Farwell
I believe those are too small for our hellcat.
I bought the 7000 ext. They work great. Only complaint is their a little heavy to hang on the wall. If I was to do it over I would get the 5000 ext. They weigh 80lbs. Each compared to 100lbs. Each for the 7000s
TrackDay
Great White North
2016 Dodge Challenger
The price on these keeps dropping I think. They were just $999 at Costco. Then Home Depot basically matched it and now $900 at Costco.
TrackDay
Great White North
I just measured between the exposed pinch weld cutouts and I'm a little less than 70" on my car. I have the ZL1 Addons adapters on the front. If I get those for the rear too I think I can use the 5000SLX. I have removed the rear pucks since my SFCs used the area.
McLovin
Syracuse
If you have SFCs installed, you should be good with the SLX.
I have the 7000SLX, and bought the extension adapters to go along with it. Figured it would give me greater flexibility with different cars.
Welp. Problem was, that once I placed the extension rails on top of the unit itself, the car was too low. So I ended up having to make 4 ramps to place in front of each wheel to drive up onto to gain clearance. Not ideal.
I bought the BMR Subframe connectors and put those on. You lose the rear rubber puck, but you gain a rail running pretty much the length of the car. So now I can jack using the front pinch weld cutout and then a spot near the end of the subframe connector. I don't have to use the extension rails, and by doing so, I have clearance without the wooden ramps.
Plus I have a subframe connector.
It looks like BMR offers the same thing (minus the connections to each other) as an jacking rail.
parttimer
crazyweathertown
you can turn them sideways and lift that way. I'd do the 7k units regardless.
TrackDay
Great White North
Yeh, but $899 though...
??? Sideways?
TrackDay
Great White North
Well, QuickJack lists 3 Costco stores near me that stock the QuickJack. The first one I called I had to finally ask for the Optical dept to talk to a human. Then he looked it up in their computer and said they hadn't had one in months and it was still $999.
Home Depot is now $1029 it looks like.
Costco online, local pickup?
TrackDay
Great White North
Av8ing1
San Marcos
2019 Charger Hellcat
Saw them at my San Marcos (North San Diego) Costco today. Kinda tempting but my garage is busting at the seems.
McLovin
Syracuse
Yeah...That's a youtube video waiting to happen....please don't do that.
