P2172 after dead battery...
ofdfiremedic
2016 Challenger SRT Hellcat
Good Morning All!
I have been searching for a forum post that is similar to the instance I have occurring, seen a few but they seem different... Long story short, I had a parasitic drain on my battery resulting in the car being dead, usually I had it plugged into the tender for long periods of sitting but since it was just driven a week prior I did not. I have replaced the battery and now have the diagnostic code P2172, I am aware of what this code is however the car has low miles and is never ran hard and problem free, just simply appeared after the car was dead. It fires up fine and within 30 seconds begins to sputter, assuming this is the "limp mode", with check engine light on as well as flashing voltage light. Has anyone experienced this in a similar fashion and found a simple corrective action. I have a code reader en route this week, wondering if clearing the code will (possibly) return the car to normal or if there is a legitimate fix that needs to be made at the dealership (which I hate). Thank you all for your time!
The car needs a throttle relearn . It lost it when the batter was dead for a period of time and then replaced . I have seen it a few times . It's a simple fix .
ofdfiremedic
ofdfiremedic
I appreciate the response, I will certainly give it a go and see what happens. From what I saw on a quick youtube search it seemed simple to complete. Thanks again!
Glad to help if I can
ofdfiremedic
ofdfiremedic
The throttle relearn was successful! Still a check engine light but hopefully I'll clear that when the OBD scanner comes in. Thanks again!
Yes the scan tool will clear it no problem.
Sounds like you are all set and learned something new !
Given the amount of issues that these cars suffer when the batteries go either dead or low, we need a "battery" button on the radio that simply says "Battery Fix"...
It would go through and reset, relearn and generally fix the car as a result of the battery going on vacation.
o_O
