New lifter install & priming 6.1L
Leduc
2009 Challenger SRT
Hey everyone,
I've recently done a cam swap in my '09 challenger SRT and also installed new Johnson lifters. While installing the valve train back onto the heads I'm getting a crap ton of valve lash between some of the rockers and the push rods.
Would this be due to my lifters not being primed? Kinda scratching my head here and looking for any helpful advice.
Did their instructions say to soak them in oil overnight? I’ve heard of too many issues with the Johnson lifters and just use the stock Redeye ones, their excellent lifters.
Redeye lifters are different?
A bit yes from the Johnson lifters. They all well engineered and after 2018 all Hellcat and RE engines were fitted with them. I’ve never read of any failures or issues with them. The 170 uses them as well including the same RE cam shaft.
I had no idea they were different than hellcat lifters
Although I have a 2022 genIII and a lifter wiped the cam. Not in a BGE though, 5.7
I’m
Problem with the lifters in these engines is how they’re oiled. The oil takes a long path that has many leak points, starts up through the heads through 2 orfices in each head gasket which where increased in diameter in 2018 too, then into the lifter stands in only 2 places per head, pressurizes the hollow rocker shafts, oil enters each rocker arm, 16 of them and travels to the tips where it enters the push rod through its round tip, travels down the pushrod then is supposed to pressurize and oil the lifter through that unsealed ball connection and no direct oiling of the rollers, their only splashed lubed from what leaks. I’ve heard of many collapsed Johnson lifters but not many if ever stock RE lifters. Johnson just had a recall on lifters I think?
Are the ports bigger in the block too or just the heads?
Just the head gaskets, that’s the advertised RE improvement of 33% more oiling to the valve train assembly, the only change was orfice size was increased in the head gasket. Aftermarket head gaskets like the Cometic MLX gaskets still use the smaller orfice size, you have to drill them out if you want more oil up top. It’s why I think some builders have lifter and oiling issues up top because no one notice's this.
IMG_4021.png IMG_4650.jpeg IMG_4651.jpeg IMG_4652.jpeg IMG_4653.jpeg IMG_7040.jpeg
View attachment 163944 View attachment 163945 View attachment 163946 View attachment 163947 View attachment 163948 View attachment 163949
I thought there was only one part number for the factory head gaskets. What is the redeye part numbers?
That looks like a huge difference!
What are your thoughts about splash back being the oil real oiling to the lifters, and the main oil gallery blocking most of the crank oil splash back? (To the roller on the lifter). And the angle of the lifters?
Factory head gasket are all the RE design now, but every aftermarket one I’ve seen still uses the smaller orifice hole size of the original design
It sucks! Be much better if they where through oiled. Powell Machine was working on a design for better oiling to the lifter roller, but I don’t know where he ever got with. It didn’t follow it.
Allegedly the DART block is support to have better oiling to the top end?
No idea, but if the oil path follows the same path through the rocker shafts as Original, I don’t see how it could be much better. The only thing that could make it better would be is if each lifter bore had its own oil hole to it with pressurized oil from the main oil galley would be great!!
50k miles down, 250k to go! :)
Great info here in this post!
Kruga
Leduc
2009 Challenger SRT
Thread Starter #18
There was no instructions that came with the lifters. The little bit of research that I did pointed me towards them as one of the best out there, but maybe I was misinformed. I'm just trying to figure out if I need different pushrods or what because when I torque down my valve train there are some rockers that don't even make contact with the pushrods. I just really don't want to pull the heads again
What cam did you use? If not stock do you know the base circle of the cam?
Did you have the heads or block decked?
Intake and exhaust pushrods are different lenghts, did you mix any up by chance?
Kruga
Leduc
2009 Challenger SRT
Thread Starter #20
I got the SRT Max Plus camshaft by Inertia Motorsports via Team Hellcat. I've double checked on the pushrods, tried both ways just for a sanity check. Cam and lifters both say that they are supposed to work with the stock pushrod length
