Last call 7.1 LB?
Anyone have an idea?
Lots of different opinions from fuel to boost so we shall see.
the guy on the right is only 7.1lbs heavier than the guy on the left
Why not just round to 7?
It's a Dodge Dart with hellcat power.
I'm still with wheels...
Boost or weight of fuel.
That's in the realm of 20lbs...
I actually got done watching your video on this after creating the thread. Great video.
Demonic Cat
I am starting think more towards boost if that’s the case were looking at a touch over 21 pounds per square inch
Honestly, it does make a lot of sense, right up until you total the numbers up...
Is 7.1 more pounds of boost worth the tease? Is that a big deal?
I think so... @Speedy! could probably even calculate HP numbers from that, or at least get in the ballpark...
Demonic Cat
Hellcat 11.1 boost
Redeye. 14.5 boost
Irish
drunkard. 7.1 added boost
Total for drunkard with one Redeye and one black Eye from fighting in taverns = 21.6 lbs boost
Demonic Cat
If It is a barnstormer with lots of grunt why not call it Black Eye, that’s what it would give the competitin.
Hellcat 11.1 boost
Redeye. 14.5 boost
Irish
Wonder if enough to get over 1,000 HP?
Demonic Cat
With just boost probably not. Rough estimate 900 925
Thread Starter #19
Would think anything less than 1,000 would be a disappointment?
Demonic Cat
Thats Rough guess could probably run numbers to verify, that would be with pump gas, Race gas with more timing would get you more, or E85 with that kind of boost no problem. Who knows lots of talk of two center stack or dual PCM
