knock retard setting
AlleyCat
Oro Valley
16 HC Challenger
On the filter frequency what are you guys using as the starting and ending point? Mine is at 6 and 45. E85, lower and upper pulleys, e85, headers, etc. Noisy engine on acceleration.
I don't know what Jon has mine at but I also have a 16 and get a lot of false knock. They changed the sensors in 18 but they are not interchangeable
Hatermkr
West bend
2016 helldemon
N
No different connectors.
I turned mine off
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
Completely off? Knock sensor one and two? Or the two values for readings to zero instead of 6 and 45?
Hatermkr
West bend
2016 helldemon
As I like a switch off
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
You are brave.
Hatermkr
West bend
2016 helldemon
I run ignite red 100% of the time. If it blows it blows
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
Understood. For pump e85 it is not as controlled as yours.
Hatermkr
West bend
2016 helldemon
This is where people think they need 85% ethonal. My Buick makes 1300hp. With the v6. Has never ran anything but pump e85 NEVER TESTED.
My friend Jude has my old 426 with a whipple 3.0 pump e85 only just went 9.052 in late October Jon can attest to no problems
ostmike
6 Second Best E/T
Portersville
2015 Hellcat
I would definitely NOT recommend turning off knock sensors in any situation.
Our Hellcat with zoomies still used the knock sensors when we were running the stock Hellcat PCM.
That data is still useful and there is no reason a street car should have the sensors disabled.
Some engines are louder and require desensitizing the knock sensors a small amount - but never off.
Hatermkr
West bend
2016 helldemon
I had no problem Turning them off.
My z06 goes into knock retard just going down the freeway I can make it happen every time
ostmike
6 Second Best E/T
Portersville
2015 Hellcat
The Z06's we tune definitely require some finesse to get the knock sensors to work the way we want them but it can be done.
You could also disconnect your fuel gauge, remove your oil dipstick and delete other similar data supplying devices and your car will run fine. However, there is no need to do this and I just wouldn't recommend it.
Hatermkr
West bend
2016 helldemon
I’m slow so it don’t matter.
