How many RPMs can she take?
Trucker Bob
Out of IL. Thank God
MO
2015 Challenger M6
I got to play with a new horse car today. I get pissed when I hit the Rev limiter and my ear tells me I should have another 1k worth of engine left. I know I would need a tuner to raise my redline. So I guess what I'm asking is what's the Readline?
Not for real, at least in mine, I get an ignition cut at 6200.
Hellcat = 6100 ish stock
Redeye/demon = 6300 ish stock
My recommendation for both tuned = 6500
After I had my 6.1 with the Magnuson tuned by AJ he set it at 6200 to be safe with that motor. I used to bounce off it constantly with the M6 until I got used to it. It felt like the motor was topped out at 5500 and I was short shifting, esp. after my big block Chevy would go over 7 and I would shift at least 66-6800. The hemi's def need a little more spin to feel snappy imo.
If you want them to sing you have to give them a valvetrain that can handle it.
Mine is tuned to shift right at 6500 , but that can change depending on ambient temp / DA , when DA is real low its making more power & will shift a little sooner vs. when its high DA , there's a lot of parameters that goes into what is going on & the shift points.
A good set of rods and pistons will definitely help too.
I thought the question was max safe revs.
Slows2k
2018 Challenger
I’ll take Speedy’s word since RPM contributed to his engine replacement.
A lot of information says weak rods were also a major contributor to the failure, but I won't be shifting mine much higher even on the RE motor.
Agreed , 6500rpm should be max on stock block.
Doesn't the Demon/Redeye have a different valvetrain that gets an extra 500 rpm on their stock tunes? They do have different red-hatched areas on their tachometers.
200rpm
Again that is what she said.
I got my numbers from looking at Tuning software for hellcats, redeye's, and demons . I'm basing it on that . Plus the logs I looked at . Yes I did see their "redline" is a bit higher on the tech then a hellcat .
NTB
Harford
Going to be pushing my 16' Hellcat to 7600 - 7800 :giggle:......
With the stock valve train?
Maxboost
Fuquay varina
6800 on my redeye.
Lighthouse Point
Redeye
I've got my Redeye set at 6450 and that's worked out real well for the last 10,000 miles...
