Fumoto & Stahlbus Valves + The Kit
Trader history for JamesU (0)
Points
Austin
2017 Charger Hellcat
I believe the best Fumoto Valve for the Hellcat's Oil Cooler is the F107SX design:
https://www.fumotooildrainvalve.com/f107sx.html
I will be installing one in December 2019 in my 2017 Charger Hellcat and can share photos of the results then. I have some confidence that it will work, especially since it redirects the drain 90 degrees and you have some (limited) flexibility in the orientation.
UPDATE: Jump to post #13 - it didn't work for my Charger.
Thanks!
Points
I ran Fumoto, for years, on my 06 SRT Charger and the wifes RT Magnum. Loved em!
I recently switched to the Stahlbus drain valve, on my Hellcat Charger and will be adding one to our 19 GC Trailhawk, next oil change.
I like the low profile, clean installation and ease of use. This has a built in hose, on the nipple, that presses into the valve, where the Fumoto with the N suffix has it molded in as part of the body.
IMNSHO, both are quality solutions, for the DIY mechanic.
Oil pan:
Oil pan, with cap:
Oil cooler, with cap:
Oil cooler draining:
Bob
Riverside, California
Octanewide
Points
House of power
Oil pan:
Oil pan, with cap:
Bob
Do you have part numbers for those Stahlbus drain valves?
Points
Oil pan:
SB-210211-S-NA
Oil Cooler:
SB-210131-S-NA
Bob
stonewall
Points
Conway
AR
2017 Dodge Hellcat Challenger
Have this on my YZFR1, and love it.
Av8ing1
Points
San Marcos
2019 Charger Hellcat
You guys are killing me...ordered Stahlbus valves.
Thanks for the part numbers Diboblo (y)
Octanewide
Points
House of power
I know your feeling.
Points
'16 Challenger Hellcat, '19 Durango
I have Fumotos on all my vehicles - top notch quality
Points
Well damn it...
Now I have to pick from my magnetic plugs and swapping to these things...
:mad:
Points
no worries, Bull. I had a whole set of Gold Plugs on all our cars, and then decided Fumotos were a little easier come drain time. Just $ :p
Av8ing1
Points
San Marcos
Thanks for the info on the Stahlbus valves. I installed them on pan and oil cooler drains today. IMG_0398.jpg IMG_0408.jpg IMG_0416.jpg
Points
JamesU
Points
Austin
Update on the Fumoto valve...
It didn't fit :(
This assessment is Charger-specific - the Fumoto valve might still work on the Challenger. But anyway, on the Charger, what I ran into was the fact that this valve hangs down pretty far past the oil drain. Once I got the Fumoto valve on, it interfered pretty badly with my access cover. So, while I like the way my access cover fits in a recessed area that the Charger has underneath the Oil Cooler, it has taken away precious space that is needed for the bulkier valve-type of oil drain solutions. Stahlbus valves are smaller - more compact.
If there are any questions, this was the Fumoto F107SX, which offers some orientation control. There just isn't a position option that could overcome the interference and still be logical as a downward pointing drain.
Points
It didn't fit :(
View attachment 9060 View attachment 9061 View attachment 9062
That's exactly the part number I was going to go with... before I decided on the Stahlbus valves.
Just did an oil change and those Stahlbus valves kick ass...
Great info &, pix. Thanks for sharing!
Bob
