FI spacer o ring size
Just wanted to post here in case anyone has it written down somewhere, I've reviewed hundreds of pages of posts to no avail. I have the size for the big o rings, does anyone have the size for the 4 small oil gallery o rings? 16GoMango maybe have posted them a long time ago however I've searched through hundreds of pages of the posts and cannot locate the part number or size anywhere for the small o rings. Would really appreciate it if someone happens to have that jotted down somewhere. Thanks!
Sorry for the delay in getting you sizes, life atm not leaving me with much free time or extra energy of late. Sizes below. I suggest use Viton instead of Buna, they take the heat better. Viton maybe 10x the cost, maybe not, have not bought a set since last year. What one can do to save some $ is use Viton on the hotter head side and Buna on the cooler blower side.
Intake ports use a 3mm cross section 60 mm ID
McMaster Buna 9262K454, Viton 9263K746 or 1295N338
Oil galley ports use a 3 mm section 34.2 mm ID
McMaster Buna 1302N513, Viton not offered by McM in this size but I have gotten them through local bearing supply houses.
Hope this helps you guys.
2ndgen
Orem
How important is that extra 0.2mm ?
Mcmaster has two Viton options in 3mm x 34.0mm size, and even one option in Silicone good to even higher temp of 450F.
U
You are AMAZING! As always you're invaluable to this community, thanks again for the information and all that you contribute here. Thanks again for all of the help and all that you do, can't say it enough
U
I found viton version of the 34.20 mm in an 8 pack
The 34.2 seems to stay in place in the groove better.
U
Zoro is where I got them, 11$ and change for an 8 pack
2ndgen
Orem
Perfect. I've bought from zoro before. Solid vendor.
U
Acquired a 2 ton hoist so that hopefully this doesn't happen again. Wish I could use alignment studs but would have to lift the blower to the moon due to length
Latest Forum Posts
