dodge and their electric demons
rookerrobert
Ridgeland
SC
2016 hellcat A8 and 2016 M6
I was just driving my car minding my own business and all a sudden it stumbled and both windows cracked as it the doors had been opened and the electronic stability came on the dash.Maybe 100 feet farther it just shut off like you have switched it off.I coasted into a drive way and stopped and when I went to crank it.....it cranked up just fine and ran fine all the way home.So the next day I bought a new battery thought that was it and overnight it was grave yard dead! I charged back up went for a spin seems mine parked and then over night dead again.Something is pulling a lot of juice.So now I handed it over to demon performance to find the problem.I know back in the 70's I had problem's with my 70 challenger r/t,my 68 gtx and also my 69 charger r/t and back then it most the time the circuit boards they used.
72 440 Barracuda
Graham
Do you have any aftermarket electronics? I added a Tazer at one point for access to the line lock function and soon afterwards my Challenger had a very similar issue. I bought a new battery and went forward but the battery was later found to be fine and after disconnecting the Tazer I haven't had the issue again... I also leave it connected to a battery tender when I am not driving it.
Year and model would help to know
McLovin
Syracuse
Check your IC Coolant pump. Just had to replace mine. It'll run even after car is turned off, and run until battery gets down to under 5 volts. It'll kill a battery in short order...
rookerrobert
rookerrobert
Ridgeland
SC
no I have a tazer but quit using month's ago and no other electronic has been added I am running dual 525 pumps but they have in the car several month's
rookerrobert
rookerrobert
Ridgeland
SC
2016 challenger with 17,000 miles.....now the blue one I took my voltmeter and with the battery unhooked it had 12.8 and when I put the cable on it only dropped to 12.7. But the orange one I done the same thing and it went from 13.4 to 13.0 I check all the fuse's relays very thing checked ok but when you attach the positive cable it has very noticeable spark. not just a little spark like the blue one.I just dont think there's anything that would draw that much fire accept maybe the alternator or maybe the pcm or ignition switch?
Could be anything it’s a 9 year old car
MJS73
Moparland
2020 Challenger Hellcat
Were they still using the same circuit boards in 2016 that they did in the late '60s and 1970?
Could be a bad ground, could be chewed wires, who knows
20HCM6 22RENBS2
If I wanted to isolate what was sucking current, I'd put an ammeter between the battery and fuse box, then start pulling fuses and watching changes in draw. I have found many bad components this way.
rookerrobert
rookerrobert
Ridgeland
SC
I would hope they were much improved it 50yrs.
rookerrobert
rookerrobert
Ridgeland
SC
thats the reason demon performance has the car they'll find out what it is....I dont trust just anyone working on my car but I do them.
20HCM6 22RENBS2
I actually think the longevity of circuit boards and components has gotten much worse. Seems like older electronics continue to work while newer stuff fails at an alarming rate. Maybe mfr's are getting good at planned obsolescence.
20HCM6 22RENBS2
I have heard, no idea if it is true, that this is a real problem for military electronics. The life of common components is completely inadequate for Mil Spec devices.
rookerrobert
rookerrobert
Ridgeland
SC
well damn that dont sound good!!!
