2015 Hellcat brake pad shifting
Just some advance hope. It takes a pretty stout hand to get them to release, or some tool assistance. If they are easy, you get some advance hope we solved it.
I noted the center bolt was not torqued to 22 ft lbs it was slightly low. I also noted the pins were not completely seated and they appear to be worn. I will replace them.
Did that fix the issue?
