What to use as a cap for the clutch line when removing CDV?
I am working on the car now and could use an answer right away. I am removing the CDV, everyone caps the clutch line but no one tells me what to use to cap it. I can't measure it until it is disconnected and dripping. Any suggestions?
Bowlerguy92
Black rubber vacuum plug from your local hardware store is usually the best bet
Don't know what that is.
You mean a kit?
Any idea what size?
Looks like they have a set at O'Rrilieys down the road, I'll go get it. Thanks!
thetalonguy
2017 Challenger HC M6
I think I just pulled the line upwards and let it drip so ever so slighty while I removed the line CDV. When done, pump the clutch 20 times and it’ll remove any air in the line.
DONE! Thanks guys.
Pulling the CDV was a spurr of the moment thing, only hitch was no one in any of the videos I watched said what they used for a cap. BG was right on, I just wasted 20min going out for them. (That, and $9!!!) :ROFLMAO:
Bowlerguy92
THANKS!!! BTW: How does a RE owner know these things?!?!? ;)
My hands weren’t always this clean. When I had more time I used to do a lot of wrenching. Hellcats are straightforward. Even was ASE certified in highschool, whatever that’s worth.
Never suspected! You seem to be more of a platinum collar guy! ;)
Bowlerguy92
Even platinum collars are washable :p
WOW!
I thought they didn't tarnish in the first place! :ROFLMAO:
WOW! Most obvious difference is how much easier it is to start from stop in 1st!!! Since day 1, the car would bog when letting out the clutch, I always thought it was the fly-by-wire throttle lagging. Now I know what it really was! It was time delayed clutch engagement! STUPID!!!! I should have done this 4-3/4 years ago!!!!
thetalonguy
Been telling you for 4 years!!!! Welcome to the club!
@16GoManGoHC2 will show you the real CDV to remove
Actually he is being serious, the small, in-line "CDV" isn't the real CDV
.02
This is the real CDV, it’s located under the brake booster.Just take it out, It comes apart, Take the guts out of it, put it back in. You’ll notice the difference. Save the guts, you could easily put them back in and make it stock again.
