Can't find OEM primary fuel pump
chrispaesano
Temple
Has anyone had a primary pump go out on a hellcat charger? Were you able to find an OEM replacement recently?
I have been to 4 different sites now, and they're all on back order. Bam auto parts let me fulfill the order and canceled the next day because it's on back order with no ETA.
Every site I go to is out of stock, Dodge has it discontinued (68258753AH, 68258753AJ).
I have this part on order. It's listed as a good fitment for my car. Will the stock wiring harness and fuse work or will I need to purchase additional parts?
https://www.americanmuscle.com/aeromotive-charger-fuel-pump-dual-525-450-lph-18092.html
If anyone here has a better recommendation, It hasn't arrived yet.
Welcome! Please do not hesitate to introduce yourself to the forum! :)
Thanks for the intro!!! We get bots and one-and-run "members" and a lot of effort is wasted, we welcome "real" actual HC owners!
I see your dilemma, the OEM appears to be out of stock. Have you considered an aftermarket equivalent?
chrispaesano
chrispaesano
Temple
Yes, I left a link in the post to the part I ordered and was curious if anyone had recommendations
I do not, but in every other car/truck I replaced fp's I used aftermarket without problems. Probably replaced 4 or 5 over the decades.
I completely appreciate your wanting to stay OEM, I would do the same. But if I was stuck, I'd choose aftermarket over not driving. Then buy a OEM when available and hold it for when the aftermarket fails.
Let us know how it goes!
I have used OEM fuel pump assemblies, if your interested message me.
Lotta effort wasted ???? really???..funniest thing you've said all year...:rolleyes::rolleyes::rolleyes: didn't realize responding to posts was so much work for you..:giggle::giggle::giggle:;)
chrispaesano
chrispaesano
Temple
Thanks, I’m starting to think there are none!
chrispaesano
chrispaesano
Temple
I’m going to stick with the new aftermarket. I appreciate the offer though!
After my initial post I remembered that I did have a prob with one aftermarket, the fuel level sensor puked and I had to take it out (drop the tank in the Wrangler TJ), bend the contacts and reinstall.
chrispaesano
chrispaesano
Temple
The mechanic is insisting that my secondary fuel pump is on the drivers side. I have a puncture in the fuel tank on that side and he’s insisting that it broke the secondary fuel pump. He told me the aftermarket primary pump that I bought is the wrong part. I’ve searched numerous forums and looked up the factory documents. I drained the tank myself trying to fix the leak prior to and I’m pretty sure I saw the pump on the drivers side too.
I didn’t bother to argue though. He’ll see when he opens up the tank on Monday.
There is no pump on the passenger side, only a fuel level sensor and a device that looks like a pump but has no wires going to it, ie it’s not a pump! Fuel is pulled from that side by a Venturi effect from the primary pump (or pumps if a Redeye). If it were me I would be highly questioning my mechanic on this. Picture of everything that’s in the fuel tank under both bungs.
IMG_4053.jpeg IMG_4054.jpeg IMG_4056.jpeg IMG_4057.jpeg IMG_4058.jpeg IMG_4059.jpeg IMG_4060.jpeg IMG_4061.jpeg
chrispaesano
chrispaesano
Temple
Thank you very much for this detailed sanity check! I am definitely questioning this mechanic. I have a great history with this shop, so I trust the owner. I may have to speak with him if the mechanic keeps up these shenanigans. I can’t wait to get out of this apartment with its sloped driveway so I can get a lift and start doing/learning.
FYI.
@16GoManGoHC2 is possibly the most knowledgeable and meticulous member on the forum (or just about anywhere). I wouldn’t hesitate to buy a new or used part from him.
chrispaesano
chrispaesano
Temple
FYI.
Understood and thank you. I have the part in hand, but if they push back on it, I won’t hesitate either. 🙂
chrispaesano
Temple
@16GoManGoHC2 can I take you up on your offer?
mechanic got the tank out, found out that the secondary sending unit was broken. Not even the whole unit either. Just the orange bracket and the fuel level arm. IMG_5995.jpeg
FYI.
100% ! Mike is smart as f___ and a great man to deal with !
chrispaesano
Temple
Wow, that picture came out great. :D They got it working kind of. I got my fuel gauge back, but I still want to replace that secondary unit. It's a little off. When I filled up the tank, it showed just a hair below full. They kind of rigged the level arm to work, but I'll replace the unit myself.
If it ain't broke....
chrispaesano
chrispaesano
Temple
ah, we cracking open fortune cookies? Here’s a couple for ya.
“That wasn’t chicken”
and my personal favorite:
“Any job worth doing is worth doing well”
